FJ80 before and after
You guys are relentless about the damn brushgard. Some people like them. I think he got the point about 15 posts ago.
-Spike
Actually I had an experience with a guy who had one on where it was useful on the trail. He got high centered on his crossmember and it provided a spot to high lift his front end up off the ground to get the rock out. The stock bumper has no provision for using a high lift.
Yep:grinpimp:. The brushguard is simple, but maybe offer some defense, from those (job sercuity)drivers. It is all could afford right now. Anyone offer any sugg. on my driveshaft grinding at 30mph? I did grease all fittings.
Spike and ginericfj80 thanks. I wish someday. anyone anyone have any suggestions for my last reply?
Yup, I suggest you do a search. :D Seriously, there's a metric ton of information about u-joints and drive shafts on the forum. Pretty difficult to diagnose your problem with just your brief description to work with. My personal preference is to replace all the u-joints when doing a lift.
Have you installed caster correction?
"J's" and "Comp's" are two different springs. Sound like you have J's all the way around. (or J's and heavies?)
BTW: Welcome. "JAFW80" :flipoff2:
Yes it has heavies and 4plus drop brackets for the casters and sorry new to the mods dept. I can't remember what I had put in It is from Man-a-Fre.
Did you drop the sway bar too? I'm not a big fan of the drop brackets. I'd go through everything and see if everything was tight. I'd be checking U joints too.
Yes the sways are droped too. Why aren't you a fan of them? I have checked everything and u-joints, and all is tight.
U-joints are fickle things. I have pulled some that seemed fine, no play by hand, but were junk. They often wear into their normal angles, so when those angles are changed via lifting the truck they can have issues.
The drop brackets, like the brush gaurd, are controversial. To me, they hang down too low and beg to be dragged on rocks. Some folks say they're not an issue. Like anything else, a lot depends on what you're going to do with the truck.
-Spike
I see.:) This is a everyday to work and play cruiser for me and they seem to make the rig handle very nice without changing the geometery of the axles. I will check the u-joints closer, and poss. replace with upgraded ones. Thanks for the info:cheers:. I will do some search here as well.:idea:
No need for 'upgraded' u-joints, the OEM ones seem to be superior to most aftermarket ones, and some aftermarkets have proven to be difficult to grease. NAPA sells a good aftermarket replacement, IIRC. But yeah, do the search. You'll find gobs of info on tons of things you didn't know you had to know. :D
-Spike
Hey Spike thanks again, you have been a great friend and help:beer:. This one is for you.:cheers:
