FJ80 ABS Braking Issue
The Land of Frank Rizzo
1994 FJ80
While slowing to a complete stop, less that 12mph, it feels like the ABS cycles and then the truck pulls to the right. It does this about 2-4 times and then the ABS light comes on. Once the ABS light illuminates the pulsating pedal stops.
I believe it is an ABS Speed Sensor, not sure which wheel. It pulls to the right when the brake pedal begins to pulsate.
Once the truck is shut off, I will start it back up and the ABS light is out, then once we start driving it starts all over again.
Any ideas??
Thanks,
John
abs sensor
it is most likely the right front ABS sensor. the light comes on when a problem is detected. it resets itself on obd1 systems when you shut down the ignition. there are trouble codes you can read before shutting off ign. they are published in the repair manual. It involves using a jumper wire & watching the light flash & counting each flash. I reccomend you have a manual on hand to follow the procedure. the flash sequence will dtermine the problem area. good luck
I had ABS lighgts and ABS miss activation and it turned out to be bad brake lines. Air was entering the system screwing with the actuator. Do you have a soft pedal? If so you might want to bleed the system.
EDIT: when I pulled the code for the ABS light there was none. This would be the first thing to do as it will tell you where it thinks the problem is.
The pedal is pretty firm, 2 brake bleeds this year and I replaced the rear calipers last month. I put on some miles since then and I don't think it has anything to do with the caliper replacement.
I have some extra sensors coming to me in the mail, I'll swap out the right front sensor and we'll see what happens. If things don't work out I'll be back seeking some more info.
I had the same exact issue. Pulled the codes and it identified the right front sensor. Turns out the connector was broken where the harness attaches to the sensor. Kind of freaky when the brakes go wacky on you while trying to stop. I've been driving with the ABS fuse pulled for a while, but finally sucked it up and bought the new harness which comes with new front sensors. Not Cheap! In the end my :princess: insisted on the new harness because of the "what if" I get in an accident and somebody proves that I had tampered with the ABS and thus caused on accident - a few hundred dollars isn't worth that liability.
After cleaning out the birfields and replacing the front bearings and 4 new calipers, my ABS was not happy. Same story: pulled to the right when braking, pulsed, and ABS light would come on. Checked the code, and it was showing an issue with the front left sensor. Turned out that I had pushed the sensor in all but a final 1mm. After seating it properly, the ABS light has yet to turn on, other than start up. However, I still get pulsing & right pull under light braking, so maybe there is still some air trapped in the system. I will bleed again and see if it helps.
Update: SOLVED!
The steel bracket that the actual sensor is pressed into got slightly bent. Probably from me tightening down the 12mm bolt that threads into the steering knuckle without the sensor being completely seated in it's hole. After some delicate pressing & grinding, I got the bracket back to near original dimensions, installed it, and... no more ABS pulsing!
Now on to the window motors, fuel gauge sensor & stereo system!
goin waaaaaaaaaaaaay back :)
