FJ62 Water pump replacement
Wimberley, TX
Cruiser friends,
I am replacing the water pump in my '89 FJ62 this weekend and was wondering if someone could detail the steps to get the old WP out of the truck. I have already removed the fan cowling, fan, and fan clutch and can see the 4 bolts of the water pump. BUT, it looks like there is a bracket on the left of the WP that will need to come off before I can get the WP out. What is that bracket and how do I remove it?
Thanks for the help.
Darin....
You have all the belts off, right? How about all the hoses to the pump? If so you're, at the 10th and final step in the FSM: (a) Remove the bolt, two nuts and PS (power steering) idler pulley with bracket assembly. (b) Remove the bolt, nut, alternator stay bracket, water pump and gasket.
WARNING: This is from a 91FJ80 manual (still a 3FE motor), so there may be differences.
Good luck,
Curtis
I have all of the above off except for (b). The pump will not come out because there is a bracket to the left of the pump that is keeping it from clearing the bolts. I cannot tell how to remove the bracket. It looks like the bracket is holding both the power steering pump and the AC pump(?). Is that the "bolt, nut, alternator stay bracket"? Have you any pictures or diagrams you can share?
There are two brackets that block the removal of the water pump. The one on the driver's side (this is step (b)) is the alternator stay bracket. The one on the passenger's side (this is step (a)) is the power steering idler pulley stay bracket. That bracket has two nuts very near the water pump, and one bolt way on the other end of the bracket, just below the A/C compressor.
That's all I got.
Good luck,
Curtis
I've got the 89 FSM, it says the same thing.
From your pics it looks like you could take that "double-nut" off that's holding the bracket on which is blocking the pump from sliding forward. I think that's what step (b) is referring to.
You don't have to remove all of that. The AC pulley and adjusting bolt come off, but not the bracket holding the ps and AC pumps. It takes some fiddling around, but you can do it.
Bret,
Did you take a look at the pics? So all I need to remove is the adjusting bolt now and the WP should come off?
I took my A/C compressor bracket off when I did my water pump. Maybe you don't need to but that was the only way I could figure it out how to get the old pump out. The thing I got stuck on is that there are a couple of bolts on the bracket that the FSM doesn't show and that are buried and hard to see. I want to say that there are 6 total on that bracket and the FSM shows 4 but my memory is a little hazy so that might not be right. No need to disconnect any of the A/C compressor lines, just unbolt the bracket and move it all to the side. The water pump comes right off after that. Make sure you clean the block real well before you put the new pump on.
sheino said:
Bret,
I did mine early this spring. The adjusting bolt, the bolt it's threaded into and the small AC pulley came out easily, allowing water pump removal. Wiggle the pump out and to the right and it will come. I think the reinstallation of the AC apparatus would be more difficult than the removal although... I didn't put mine back in because I kinda forgot about it until it was too late. :o Oh well, it's never used here anyway.:D
Spent 3 hours last night trying to get my WP off of my 88 62. The two right bolts that attach to the alternator bracket had seized up inside of the holes in the WP. It literally would not budge. Having the mechanic check it out this morning because I gave up. Anyways, just thought I'd vent.
