FJ62 Trans ?
They'rEarl be a hot and cold mark...
I check that cold... which is a waste of time... heat it up, run it around the block or check it after you come from somewhere...
You'll want it to be at the top of the hot mark, no higher.
Do you have a 62 trans in your 80? That seems to be an easier way than a part time kit.
Well at least for mine it would be easy.
What is the right way to check the fluid level. Engine on or off? In gear or in neutral? thx matt
This info is in the owners manual.
Engine at normal operating temperature. I usually run around the neighboorhood for a while. Park on level ground with the engine running. Run through all gears once and back to park. CHeck fluid level. Should be at the HOT mark.
