Can a stock FJ62 instrument cluster speedometer run off either its own original cable running to a GM 700r4 - NP241 trans/transfer (1989) or will it be better to have the GM cable running up to the speedometer with some sort of adapter?
OR
Use the electronic style VSS from a slightly newer 700r4 - NP241c (1990-1991) and convert it somehow to work with the Toyota mechanical speedo?
All of this will be attached to the stock 350 TBI and all swapped into a FJ62
OR
