The reverse lights in my 1988 FJ62 have been out for years and yesterday I gave my best trying to fix them to no avail. Here’s what I have done so far:
-Pulled both lenses and applied 12V to connector, bulbs light up.
-Checked my Kaymar Bumper wiring done by me and no splices for the brakes or marker lights touch the stock reverse (Red with Blue) wires. Kaymar blinkers, brake lights, and red markers all work fine.
-Opened rear quarter panels and checked connectors / wiring, no corrosion or open wires.
-Checked 20A Wiper fuse which is good and also runs the wiper motor, washer motor, and other wiper stuff.
-Confirmed Neutral Indicator light comes on when in between 4Hi and 4Lo (which is part of reverse light circuit.)
-My truck will not start in any other position except P and N so I assume my NSS is working properly?
I did not check the reverse lights ground location “c” which is “Located under left front pillar.” Since the stop lights and marker lights work, I assume the grounds are in good condition. That leaves the following to check:
1. “back-up light S/W” which I cannot find.
2. Transfer Neutral Position S/W which is in series with the neutral indicator light and the NSS.
3. How do I confirm my NSS is working and is communicating with the reverse lights?
I have a spare trany and tcase dropped in my garage so I have spare parts to swap in if needed. In the FSM on page AT-6, diagram number AT1271 shows the NSS test and there are two connectors with 3 pins each. This is confusing because the NSS in the wiring schematic only shows two contacts; one going in (which is in parallel with the 12V Wiper fuse and the Back-up light S/W) and one going out to the “Neutral Indicator Light.”
