FJ62/3FE sheared one of the serpentine pulleys
You're going to need a new timing cover seal, also.
Hard to tell from the one pic, but is your keyway on the crank snout wallowed out or ok?
For the Harmonic Balancer certainly you can't beat the OE Toyota, but there are aftermarket from Dayco that are under $200 if the price of admission of the new OE is an ouchie. I didn't read where 3_pups said he had a used 3FE pulley, which would be fine, too, if available.
Good luck.
Good luck.
The keyway seems intact. Which part would be the harmonic balancer?
Looks like the timing seal is still available direct: 1132861010 - Gasket, timing gear or chain cover. Engine - Genuine Toyota Part - https://parts.toyota.com/p/Toyota__/Engine-Timing-Cover-Gasket/62991446/1132861010.html
HB is the pulley that disintegrated.
You're very lucky that thing didn't let go at high speed...
Also, you linked to the Cover gasket... The round rubber seal that is around the crank snout is what will need replace.
And you're gonna have to find a new crank nut. NLA from Toyota
Ah ok so harmonic balancer = crank pulley.
Looks like these folks have a crank nut: https://shop.cruiserparts.net/index.php?main_page=product_info&products_id=39667
Would this be the seal needed? https://shop.cruiserparts.net/index.php?main_page=product_info&products_id=61917
Good luck.
I do have the pulley, nut and most likely a key, trying not to peddle wares in tech.
the seal can be finnicky in the timing cover, caution is advised, the cover is easy to deform if using extra force
Any better pics of the crank keyway? The sort of failure that I see in my nightmares. One of my biggest fears running my 2F daily is the HB letting go at speed. As @Spike Strip mentions very fortunate this wasn't worse. GL.
It’s a little dark out so this is the best I can do till tomorrow.
Alright, after working with 3_puppies(many thanks!), I've sourced the crank pulley/harmonic balancer/crank nut/key + fan blade/shroud. I've ordered a new set of fan belts and an oil seal. Should that be about it for the parts on this job?
