FJ60 Starting Issue- HELP~
FYI don’t go w/ an electric pump. They suck and are noisy and simply add problems that truck was never meant to have.
Most carbs empty overnight or a few nights. The fuel seeps out. This is a well documented issue. No sense beating a dead horse. Sounds like he followed the directions @OSS provided and they worked. Do all this w/ the hood up and you can jump out after a few times priming the carb to see the level in the sight glass.
Keep it simple and don’t complicate matters. It’s a 30 year old truck, it’s not going to do exactly as asked each and every time. If we all wanted consistent we wouldn’t be driving around 30 year old tractors.
Not necessarily. I’ve done it on other vintage cars I don’t drive often. I keep the mechanical pump but run an electric in line just to prime the carbs, it works fine.
If the accelerator pump seal is worn, it won't squirt as much gas with each pedal pump. When they're really worn out it'll just dribble fuel instead of squirt it with force into the manifold. The forceful squirting is important when the engine is really cold cuz it helps atomize the fuel as it splatters on the bottom of the intake.
Maybe it's not the problem, but best to rule it out by taking a peek down the carb throat when pumping the gas
The pump seal as in the accordion rubber boot which has a tendency to always break down over a short time? I remember rebuilding my carb and I swear it was only six months later the boot was all cracked again.
Appreciate all the feedback, guys! The weather's warming up here so I may not find out what the real culprit is until next winter...which will be a while down here in the south. I'll think I'll start with a carb rebuild and slowly tackle the older components along the way.
Gave 5 good pumps this morning, pulled the choke, and she fired right up...granted it was 45 out...so.
All in all, I can't complain... a little temperament in the morning is understandable given the bad-assery of these rigs.
Keep you posted on the findings.
Red tops suck
