Hey all- long time!
So, I picked up an 87 FJ60 a couple weeks back and I'm running into a starting issue, specifically cold starts. Here's the breakdown:
-Stock 2F with the dreaded MSD ignition (pic below for reference)
-Brand New Optima Red Top
It fires right up when temps are above 50 no problem. Pull choke, crank, fire. Easy peezy.
When the temps are cold, say around 30, I can't seem to get the ol’ girl to turn over….just cranks. I use the same starting process ( a process I found here on the forum that works flawlessly…when warm). The only way I can get this rig to turn over when cold is to jump it with my wife’s 4Runner. The battery show around the 10V mark and will crank all day, so I'm 99% sure that's not it. So the questions is…is the MSD ignition bad? Does it need a full 12V to fire, and therefore connecting a jump to it gives it more than enough juice to do so? I already went through the obvious trouble shooting- Starter, alternator, fuel in carb window, etc.
Anyone run into this issue? Any advice would be spectacular!
( second pic is with the new wheels/ tires…just because
