FJ60 Started running rough
I have a 83 FJ60 that started running very rough last month. It was fine and one day it just started bucking/lurching/no power or whatever you want to call it. When I leave the house in the morning, it runs very weak and can drop in power or buck as I am driving along. It will usually start behaving much better at high rpms and speed.
I replaced the plugs (looked very bad) and the wires (including the distributor cap). It still seems to have bad performance.
What would be the most likely culprits? Any help is appreciated. Thanks!
Have you done a look see with your vacuum lines ? Have any worked loose ? or possibly just not a tight fit. Less likely since you said it is better at higher RPM's but it 'could' be a dirty fuel filter.
If you do replace any vacuum lines get the metric size.
John
Does the engine do it only cold? Could be choke cable or the choke plate not closing all the way.
