FJ60 long range tank
Kansas city MO
For sale 1 MAN-A-FRE FJ60 longrange tank allmost new, Installed filled drained removed. due to a change at man-a-fre the sending unit is in the wrong place and dosent line up with the access hole. Replaced with a corected unit.
Thank new from man-a-fre $925 plus around 200 shiping
AS IS $700
The sending unit could be moved.
Rob - I am pretty sure it won't fit on a 62 without a lot of work - not "Plug and play" ???
differences are pump in tank and no pump in tank would work with external pump for 3fe conversion in a wagon tho! THANK YOU rob for taking care of the owner of the tank. as you can see i'm busy.
