I have looked and can not find any other upgrades for the fj60 front brakes than 4runner calipers. Is this because this is all that is available? with in reason of course.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Mace, later Tundra rotors are 231mm. Take a look here. Side-by-side comparison of factory J6x rotors to Tundra rotors.
If they are bigger, they aren't 231mm if that is a diameter. Stock 60 series rotors are 300 mm.
Not necessarily, depending on how much wider the stock front axle is than the rear and how much the brakes add on. Front track widths are typically wider than the rear.
You can retrofit Tundra rotors and calipers onto a FJ60 front axle if you use IFS hubs and these brackets from front range offroad. Baxter650 used these to mount Tundra brakes for his build:
http://frontrangeoffroadfab.com/nfo...d=136&osCsid=3298950822b675f9efbbcd7790bb3f42
So, I wonder if using the IFS hub if wheels with a greater backspace could be used without the need for spacers.
You'll get a greater performance increase with a decent tire and pad combined with proper maintenance.
Larger brakes work well on a properly designed system. We tend to piece things together and end up with better pedal "feel". More times than not, there is no actual increase in braking performance short of a slight increase in fade resistance.
My HJ60 with stock rotors, pads, calipers, M/C and no rear prop valve brakes better (on 33's and OME) than my FJ62 with 4Runner calipers, 80 series M/C and a properly bled and adjusted rear prop valve (it is also on 33's and OME).
Dan
