- Joined
- Oct 7, 2006
- Threads
- 32
- Messages
- 92
Putting the FJ60 engine into the FJ40 (2f to 2f swap).
I read on here that I need to change my motor mounts.
Question 1:
Motor Mounts
DO I need to replace the front or rear?
I think I read I need the new front ones if my mounts in the front were round
OEM are pricey boogers.
I was going to get them from Cruiser Outfitters. WHich ones to I get though?
Motor Mounts
Fits 69'-7/80' FJ40/55
Part# EGM60010F Front Round Motor Mount - $10.50
Part# EGM60022F Front Square Motor Mount - $18.50
Part# EGM60010R Rear Round Motor Mount - $6.00
Fits 8/80' -7/87' FJ40/60
Part# EGM61020F Front Motor Mount - $25.50
Part# EGM61020R Rear Motor Mount - $64.50
Fits 8/87'-1/90 FJ62
Part# EGM61030F Front Motor Mount - $26.50
Part# EGM61041R Rear Motor Mount - $69.75
Question 2
Bolts
I will need new bolts to bolt the 2f on. What size bolts do I need? Can I get these from a dealer? Do I ask for the bolts for a FJ60 2F when I order the bolts?
Question 3
Starter
I plan on using the starter from my 74 2f.
Question 4
Distributor
I read I CAN use the FJ60 distributor, but the wiring is different and it needs the FJ60 ignitor. So how different is the wiring? How much work would using the FJ60 distributor entail?
Question 5
Clutch Slave
I don't have the clutch slave. Can I use the FJ60 clutch slave? I think I have to swap the 74 clutch slave and flywheel in.
Question 6
Oil Filter
Which one do I use? The one from the FJ60?
Question 7
Manifolds
DO I use the manifolds from the FJ60?
Question 8
Misc.
Anything else I should do when I put the new 2f in?
Thanks for the help.
Question 1:
Motor Mounts
Motor Mounts
Question 2
Bolts
Question 3
Starter
Question 4
Distributor
Question 5
Clutch Slave
Question 6
Oil Filter
Question 7
Manifolds
Question 8
Misc.
