84 FJ60 - F2 Engine - Desmogged - Stalling at crank issue
Purchased this 60 from a local guy about 6 months ago. It's ran pretty good except for a distributor issue that we had fixed. Replaced a DUI with a new DUI after the old one died.
About a week ago, I filled up with gas and ran a bottle of SeaFoam through just as general maintenance. Drove through that tank of gas and then filled up again. Almost immediately I noticed a very slight loss of power going up a hill but didn't think much about it as I figured I was just in too high of a gear. No issues after this initial loss of power.
The next day I noticed a much heavier gas smell inside the cabin. Again, not too alarming since it's an old carbureted car. Seemed to be running fine, then it just died going about 45 down the road. But it didn't "die" - seemed more like it was getting starved for fuel or missing. Rev and almost die, rev and almost die.
After stopping, I couldn't get it to stay running after cranking. It will crank and idle normally for about 2 seconds and then die. If I press the gas it will rev and die, rev and die.
I have checked the following assuming it was a fuel delivery issue:
Replaced fuel filter - thinking the Seafoam dislodged some sludge
Cleaned spark plugs - were a bit black but nothing concerning
Checked for vaccum leaks - none that I can identify
Don't see any trash in the carb, and seems to be sending fuel when cranking
Bowl is filling with fuel on the carb
Fuel pump (mechanical) is sending fuel - a steady stream up to the carb when cranking
Adjusted the fuel mixture screw to rich and lean with no change
Any suggestions from here?
Should I check that the distro is firing on all 6? And if so, what's the quickest way to check that as a novice shade-tree mechanic?
Also, I'm fairly new to FJ60's but somewhat mechanically inclined. I probably won't pickup on abbreviations or short-hand terms, so please respond "kindly"
Thanks in advance!
Thanks in advance!
