FJ60 Blower Motor just quit working
Dead again ,only lowest speed.
Unplug the connection at the motor under the right side of the dash. Put a meter on each of the contacts & have someone switch ‘on’ to each speed in order to determine if you are getting 12v to the contacts. If no…get a new motor from Classifieds or someone parting out a 60.
I had this issue & got a ‘new’ used blower motor from Proffitts Cruisers. I got lucky & the brushes & the motor itself looked hardly used. 3 screws to get to the motor…$75 & I was good again.
Ran for 20 minutes after replacing the selector switch,adding a seperate ground to switch and installing a new reset able breaker in the fuse panel to lift of steering column.All speeds dead.
Are you getting 12v when you click ‘ON’ at each speed as suggested in post 42?
