FJ55 rear disc conversion
Has anyone installed the rear disc conversion kit on an early rig from JT Outfitters? It looks pretty complete and sounds like a clean conversion, but I'm wondering about proportioning issues and brake-line splicing, just wondering if anybody can relay the little details NOT covered by the kit to give me an idea of the scope of the complete job...
A rear disc conversion is pretty simple.
Unbolt the drum backing plates and bolt on the caliper holders.
The JTO kit looks pretty complete.
You might have to shorten the lines a little or bend up some shorter ones if you're not confident with the flaring tool.
Putting the kit together yourself should cost about half as much.
i think someone just did it on a 40 and posted up. iirc, he had some issues but was happy with the stopping power
geee...imagine that...issues with jto's crap.
I am also looking at a rear disc brake conversion
Just in the planning stages. I have a 76 FJ40 and would like to do a rear disc brake conversion. Any advice would be great? I would like to put the parts together myself. My main goal is to upgrade to discs and move the ebrake to the rear axles. Matching with my 13bt and H55f install. What are the list of parts required, are their cheaper sources for the required parts? JT is a little pricy for me and shipping to Canada always comes with significant costs. Thanks
Guys, do some searches!! sheeshh
this stuff is discussed weekly, the part #'s are on this board to do the whole setup complete without having to purchase a kit. Downey and others have the hoses you will need for the axles, email poser for the brackets and the proper trimmed rear discs, go to your local auto parts store and get some loaded calipers, and whalla! you are done. Then, post up specific questions if you have problems.
noah
check tsm. they will sell just the brackets and you source the rotors/calipers, iirc.
ebrake setup for rear discs
I found almost everything I needed under the search menu for rear discs. I also need to move my ebrake back there, but I see JT sells calipers with ebrake on them so the options must be out there. I will keep searching. I am always impressed with the amount of information availible on this site. Thanks:)
