FJ55 Gauges and Bedliner
Park City, Utah
MY digital sort of $hit the bed a little while ago but I promised someone pics of the gauges and found some of them in my photos of my bedliner spraying... Sorry, no closeups of the gagues unfortunately.
The gauges are Autometer Z series but I didn't want to fork down for all of them so bought a set of AutoGauge (cheap version from Autometer) for the volts, oil pressure, and water temp. All work great. The other ones are "diesel specific" a pyrometer (diesel exhaust temp), boost gauge, and a tach as my FJ55 never had one. The tach included a band to attach it to the alternator. This is a very easy way to get a tach installed and is low reving (I think it maxes at 5000 rpms) so this would be great for a 2F as well. Except that there is a small writing on the gauge that reads "diesel" but some of you might think that is cool. Better than a tach that goes to 8000 rpms I think...
For the bedliner,
Also a neat tip is to use a spray gun, I used a $8 "Rock Schutz" gun from Harbor Frieght and xylene from Home Depot to clean it up. If you take a close look, you want low pressure from a large air compressor (like 25 psi) and higher pressure from a smaller tank. I used a 26 gallon and set it at 40 psi and it did great. The shutx gun also has an adjuster to slow down the air but it is not very minutely adjustable but might work fine. Generally, if durabak/herculiner/whatever is dripping out of the tip of the gun, you know you have it set too low. I did this the first night and wasted a lot of durabak....
I sprayed Durabak the first coat but ran out. You can only order Durabak online (www.nonslipcoating.com) and I had heard good things about it whereas most herculiner is rolled in so I didn't like the look as much. So I called them up and said "I need more now!" and the guy spilled the beans that Durabak and Herculiner are exactly the same thing... Difference is Herc mostly comes in black and Durabak can be ordered in a big variety of colors. Herc is also available all over, Autozone etc etc etc. Even my local Carquest carries it. So, I bought two more quarts of Herculiner and it did great. Spraying is also definetely the way to go, just make sure it's ventilated well otherwise you will kill millinos of brain cells...
http://www.collegeinternetsolutions.com/cisautoweb/fj55/bedliner/
DocB said:
A newly Arma Coated 40 tub up the firewalls like yours. A MAJOR PITA to pull the interior, prep, and do right.
Yes I agree... I was also deep into rewiring as you can tell - if I were smarter I would have sprayed when I had the interior all torn down. For the gauge cluster, it is something I made from scratch with some 16 gauge and 1/4" thick x 1" wide strap. Here is a photo of the original dash with the vacuum assist. I do like the gauge cluster quite a bit :) And yes NV4500s are yummy! :)
Sorry JAson, I saw your post on Pirate too. They ere on these when I got it. I believe they were laser cut but they are hand made. Metal that is a pretty neat material, flat on the back side (the part you don't see) and textured to look like vinyl on the door but still metal. Problem is they are loud but not bad. Held on with a dozen flat head screws for each door, small drill holes in the panel and door to get them to fit so not using the OEM plastic snaps. I'll take some better pictures but here are some decent ones for now. I think one I put some sound proofing (aka Ice Shield or "bitchathane" as its called sometimes) on the doors should quiet it down a lot. They are pretty sweet though, I like them more than OEM because they are more durable..
http://www.collegeinternetsolutions.com/cisautoweb/dtlc/fj55_2/DSCF0255.JPG
http://www.collegeinternetsolutions.com/cisautoweb/dtlc/fj55/70 - 7 3.30.03.jpg
All old school but they basically all look the same... :)
Sign that you do not have it adjusted well (too little pressure):
http://www.collegeinternetsolutions.com/cisautoweb/fj55/bedliner/IMAG0200.JPG
About right: (this is overspray from spraying the panels)
http://www.collegeinternetsolutions.com/cisautoweb/fj55/bedliner/IMAG0201.JPG
You can see the ganules spray more evenly. This is also the best way to maximize your product, I used way too much of it because of spraying it wrong.
Here is a comparison of the two.
http://www.collegeinternetsolutions.com/cisautoweb/fj55/bedliner/IMAG0202.JPG
A gallon will do a 40 tub easily. If you spray it uniformly then 1 gallon and a quart should do. I sprayed thick mostly for ound proofing as well. Which did not work as well as planned and will have to sound proof as well anyways...
