FJ55 Dizzy not seated %$#@
Colorado springs
Had some distributer problems with my 74 FJ55 F engine
Took the cruiser to my mechanic. Sure enough my original dizzy was old and worn out after 32 years of service. Who'd have guessed it. He replaced it with a Mollory dizzy Some new oem 7mm wires as well.
The mechanic pulls up in front of my house last night for a test drive and to drop him back off at the shop. She felt pretty good.
I go out and start her up to make my way home.....And there is a loud metal squeel noise from the starter area. He takes a look at it. Decides it is probly just the starter getting ready to die.(Sound only happened when stating not while running)
So I leave the shop make it 150 feet or so and the cruiser shuts off in the middle of the intersection. I coast into a parking lot, call the mechanic, tow back to the shop.
As it turned out he did not seat the dizzy the appropriate two clicks. Causing the engine to be staved of oil. Thus solidly freezing the engine. like a rock.
Looks like I may be getting a new engine now though. The good side to yesterday is that I got a promotion.
Anyone else ever have this happen?
Sounds like you need a new mechanic. I hope he is buying you a new motor.
I had a hard time getting my dizzy back in after removing for some new rings and head work etc. I thought it was all the way in and even bolted the bracket down but the bracket didnt sit down flush where it did before. It was engaged with the gear but not lined up with the oil bump. I had it in and out several times rotating the slot on the pump with a long screw driver before it went in. I can see with a new dizzy and someone who is not paying attention can really screw up a motor.
I would not say that this is common but I have heard of it occurring.
One thing is for certain:
If the distributor is not seated in the oil pump, you will not have oil pressure, which, even with an OEM instrument, would have been indicated, provided it was working before hand.
Given all the noise that's been made about this, year in and year out, on this board, and given that this type of mistake is possible on just about every other engine made, I'm amazed it happens at all, particularly when you know the distributor has been messed with!
I always watch my gauges when starting my FJ40 - the oil pressure better rise in the first ten seconds, and the amperage gauge better not be doing anything funny, or the ignition gets shut off, RIGHT NOW!
Maybe I'm just old fashioned about monitoring equipment, or perhaps we've all been dumbed down by the christmas tree of instrument lights that all flash on when a modern vehicle is started...
Kirk
Being aware of what it going on around you is not old fashioned....but it does seem to be lacking in some folks today.
:beer:
It seems that at least every few months someone posts about losing their F series engine due to not seating the distributor. My friend lost his first cruiser engine due to this. If it is not in the FAQ something should be added to address distributors and their penchant for killing F series engines when not properly installed.
Does this problem just exist in the F's and if so, what is different in the 2F's design?
