I'm back on the road Again! (no longer fawked!)
Romer
fatherofdaughterofromer
Moderator
Centennial, Colorado
Well I am back on the road again!!! I learned a lot and made some good new friends.
Figured out part of the reason my engine seized was because the Toyota Hold Down clamp for the distributor makes it sit higher, that and the fact I had it loose, allowed it to walk on me while I was doing the timing shutting off the oil pump.
Turns out my #2 and 5 Piston bearings were shot and they were what locked up the motor. #2 main bearing was also a little marked up and we changed that as well. As soon as we dropped the #2 piston bearing, the engine would move by hand. We were able to do this all while it was in the motor without removing the crank. The crank was not damaged and we used emory cloth followed by wet sanding the crank with 200 grit Sandpaper to get the bearing material off. We learned an awful lot about bearings.
My engine had recently been rebuilt and looked really clean inside. The rebuilder had used .10 over (.25) piston bearings. What threw us for a loop for quite a while is that the top half and bottom had had the notches oriented differently. Some had the notches butt to Butt and some were going the same direction (180 deg apart). We thought that the 180 deg apart was the right way to go, but when we torqued them down, the engine
would not move. We then flipped them all the other way and the engine moved perfectly. This makes sense, because if they were 180 apart they both could rise slightly out of the grooves(both would have to), but being butt to butt (facing each other) they had no where to go.
So we replaced all the Piston Bearings and only the #2 Main bearing. All the others looked fine. We used assembly lube as we installed them. We then installed the DUI Dizzy and it runs great. We primed the oil pump with a drill and screw driver prior to starting it. The DUI “seems” to give me a little better take off and better performance on the highway. I only drove it home from Ige’s. I’ll need to drive it some more to really gauge the difference.
Oh, I did not require the side cover being swapped for the DUI, but we could see based on how it goes in, that the dimpled side cover could be required. We had to take it out and re-orient it.
Ige and Shawn were tremendous and really helped me out here. Mike (Treeroot) also was there ready to take apart his extra engines when we needed something.
Better than getting my cruiser fixed is the fact I made some great friends and learned a lot.
Ken
Oh and one of Ige and Shawn after we got it running. Looks good next to her 45, with her 40 in the background.
You'd'a thought they'd take the opportunity to reorient your bezel for you (in honor of the rebirth of your truck, of course!). :D :flipoff2:
Goes to show how adversity can become opportunity: a lotta good came out of that! Congrats!
Ige thought about and then said that next year a Moab everyone will know that's Romer.
Don't know whether that's good or bad!
You know I like it the Bezel the way it is.
congrats on gettin her back runnin romer
it is just awesome to find out that there are cool people out there that will help anybody out
malphrus
This is the type of stuff I LOVE to hear about. With a lot of other hobby sites I've visited, it seemed more of a place to air out people's gripes with one another than a place to share knowledge and make friends. I'm glad this place is different.
:cheers:
Nik
Drove it over 100 miles today. Ran great and felt great. I will be checking the gas mileage this weekend when I fill up. It seemed to ride at 70 a lot easier with the DUI Dizzy than before. By easier, the engine didn't seem to be working as hard.
Got a little nervous when I looked won and there was no oil pressure. Pulled over real fast. Oil sender connector slipped off. Put it back on with no other issues.
if it's the little plastic connector like on your brake switch wires, you might be able to reach in there with a screwdriver and press the looped parts of the spade fitting down to tighten them up. if you bust it, swing by sometime after i get back from norway and we'll replace the fitting with a newer snugger one.
romer, here's shawn when he finally woke up the next day...apparently, he likes to take after butch when it comes to other's motors.
That's priceless. Now I don't feel bad about posting the picture of your 60 towing a heep to your house.
Got your message that you got it running by 10. Is it gone from your house? I know it was making you "uncomfortable" to have a heep on your premises.
Disclaimer - Ige was allowing shawn to fix a Jeep for a good friend of theirs. They tried to talk him into a 40, but it was a no/go. He must be a pretty good friend for her to do this.
Ken
