FJ55 camber, caster issues
Portland, OR
Hello Mudders,
Nooby here. While driving my 55 from Portland, OR to Moab to do the White Rim Road in Canyonlands we experienced several encounters of violent swaying when hitting an irregularity in the road. We stopped off at a tire store and they adjusted the toe-in from L :-0.05 degrees and R :-0.08 degrees to +0.18 degrees each. This seemed to help a little but we compensated by driving between 50-55 and letting off the gas as soon as a hint of sway was detected. The traveling to and from wasn't much fun the the time in Canyonlands was awesome!
The alignment sheet provided by the tire shop showed the camber to be L : 0.0 degrees and R : 0.6 degrees verses spec of 0.8-1.3 degrees and the castor R,L : 0.5 degrees verses 0.8-1.3 degrees. My understanding is that caster can be adjusted with shims although 0.5 degrees seems pretty small. On the other hand I understand the camber is a function of the solid axel which is what it is and can't be adjusted. The PO had installed disk brakes from and early 4Runner or PU (I think) and a chevy power steering unit was also installed. I plan on installing all new rubber bushing in the shackles and a steering damper to tighten up the suspension. I am not sure how concerned I should be about the caster, camber issues. I could look into wedges for the caster but should I be looking for a better axel housing to address the camber issue.
Thanks for any thoughts,
It does have the rear sway bar. Wish they had put one on the front. I understand the new underwear reference: very frightening when the "death-sway" (shall we call it) rears it's ugly head. I guess I should order all new bushings for the sway bar too.
You describe a "violent sway".. it would be helpful if you could expand on that. Is the wheel shaking? Are you having trouble correcting and having to make multiple small adjustments to get it back on line? I suspect from your description its actually the "death wobble".. this search term will help you find more help.
Tie rod ends, relay rod ends, play in the steering box, wheel bearings, king pin bearings (you need to get your eyes on the races), spring bushes, spring u-bolt nuts.. all of these require close inspection. If the vehicle is otherwise driving normally and it has no lift installed then adjusting castor and wheel alignment would be pretty low on the list to resolve a death wobble. Additionally, often you won't find a single root cause - small amounts of play or issues in multiple areas can contribute to the death wobble.
Maybe because it has power steering I didn't feel much feedback through the steering wheel. I torqued the wheel bearings to spec before leaving on the trip. A local Land Cruiser specialist looked over the play in the steering components and thought they didn't look too bad. I researched "death wobble" and it appears that is related to front wheel shake. The whole car was swaying back and forth as if there were no sway bars. It appeared that slowing down was the only way to reduce the sway. It has stock lift with 33" tires.
Just crawled under the beast and discovered that the bushings in the sway bar rods are shot so I will order and instal those as soon as they come. That should help. Along with the suspension bushings and steering damper. I will report back after installation.
