Fj45 2f to 2h conversion
Australia
The old 2F has finally decided to give up, and I knew its time was probably getting close anyway.
A few months ago I picked up an 82 HJ60 with the 2H and 4-speed specifically for this reason, so I’m looking at swapping the complete engine and gearbox into my FJ45.
My main questions are around the mounting and wiring.
Will the HJ60 gearbox/crossmember bolt straight into the FJ45 chassis, or are the chassis mounting points and spacing different? I’ve read a few different things about using the HJ60 crossmember versus the HJ45/HJ47 setup.
Also, what needs to be changed electrically to go from the petrol ignition system to the diesel? I’m assuming I’ll need to modify the wiring for the glow plugs, starter, alternator, gauges etc., but wondering how much of the HJ60 wiring/harness is worth transferring over
Cheers!
  • Transmission Mount
    • The HJ60 cross member wont work
    • The FJ45 Cross Member wont quite work either, the actual cross member will be correct but the two "L Brackets" that bolt to the chassis rails are a slightly different angle to the HJ47 ones and bolt to a slightly different position.
    • If you could find a pair of HJ47 "L Brackets" then they may bolt up, as many FJ45 had both sets of captive nuts on the chassis rails.
      Without an EDIC setup you wont have an engine shutdown.. you can use a stop cable instead.
  • Electrical
    • A simple glow setup with a big fat solenoid driving 10.5V plugs would be ideal.. (Plugs Toyota 19850-68010, NGK Y-147T, Denso DG232, Bosch GPT218, Champion CH133, HKT PT 145)
    • You wont have an "EDIC" and that would be a big job to get working, a simple "Stop Cable" will suffice to shut down the engine (see images linked here)
    • Alternator, wiring will depend on whether its externally or internally regulated.
    • None of the HJ60 harness is worth transferring over, your FJ45 housing as 95% of what you need.. the final little bits for Glowplugs is trivial to retrofit
  • Other
    • You'll need a vacuum reservoir tank
    • You should fit a sedimenter or secondary fuel filter
  • Electrical
  • Other
Thank you that helps a lot I do have a set of hj45 cross member L brackets that should work and yeah the 2h in the 60 did not have a edic someone has removed it and replaced it with a pull cable which make it a lot easier for me can use the existing bracket. Also will be pull the secondary fuel filter from it to go into the ute but what’s the vacuum tank for?
The tank keeps your vacuum consistent. When you need vaccume most, at idle, you'll have very little from the alternator/vacuum pump and when you need it least, at RPM,you'll have too much. The tank keeps it even all round.
Your other option, if you're installing or have power steering, is a hydraulic master cylinder for your brakes and do away with the vacuum system completely. This means you can keep your simple/cheap 2F alternator.
...None of the HJ60 harness is worth transferring over, your FJ45 housing as 95% of what you need.. the final little bits for Glowplugs is trivial to retrofit
Great suggestions, as ever!
Planning the same swap for my future BJ45 pickup resto: Got a good 2H engine from a 1985 German HJ60 and gathered all the parts Duncan suggested me a year ago. The question is that the 2H is from the German market, so 24V.
Not sure I can a use a complete 12V FJ45 harness/relais I have: should I keep the 24V BJ45 harness/relais?
