The fuel sender wires are yellow/red and white/black (ground, which you can wire to a cleaned area on the chassis). They should run in the same small harness as the seatbelt switch wires from the frame rail to the cab. Yellow/red originates, however, in one of the larger plugs on the firewall. You should have a yellow red wire in one of the large plugs on the firerwall in your first photo. That wire should run down the frame rail and turn inboard to the hole in the center of the tub floor aft of the xfer case.
Now that I think about it, do you have the seatbelt and backup switch wires hanging from the loom on the ps frame rail? I believe the wires from one of the large plugs and the disconnected small plug on the firewall in your first photo merge near the middle of the truck.
Yep, that's the VSV plug on the ds fender. (Blue/black, blue/orange, black/yellow, blue/red, and blue/yellow wires). The VSV is the original smog control box with a dozen of more vacuum tubes going to it. I don't know what vehicle that voltage regulator is for. It looks aftermarket. Does it have a brand name?
Correct. The area on the firewall with the two bolt holes, where the speedmarker would have been on your 75, is where the '78 voltage regulator was mounted. (White/black, black/yellow, white/green wires).
Todd.
Just noticed something. The regulator on the left in the last photo above is not the same regulator that you show in the third photo at the start of the thread. Anyway, it doesn't matter. The plug in the third photo at the start of the thread is for the VSV. I wasn't trying to imply that the box in that photo was the VSV.
