Fj40/v8 Electrical
'71 fj40 w/283 V8 been sitting for 8 years. The electrical system is shot. DO I go w/a harness or rewire it? If Harness, is there a economical one out there?
We got it started but only the driver side headlight works. Nothing else, including gauges. A friend said to spray CLR to clean the rust and corrosion off the wiring. I can rewire by running the wire parallel, cutting then reterminating.....HELP!
for $150, the ez-wire kit cant be beat. everything is color code and labeled. Saved me a lot of aches and pains. You do need to buy the terminals- which I got from Waytek. I used GM weather pack, but you could go cheaper and use butt connectors.
-Dustin
It would be hard to say if it needs to be competely rewired without digging into it first. It might just be a bad fuse block and ignition key circuit.
I would start by printing out the OEM schematic and figuring out how to read it (it is a mess compared to later schematics).
http://www.ih8mud.com/tech/72fj40-wire/71fj40_wire.gif
I would start by tracking down the main feed wire (12 ga white wire and white with blue stripe) from the battery + post through the amp meter to the ignition switch and fuse block. After making sure that the fuse block and ignition switch are getting power (both volts and amps; not just volts only), if things don't start magically coming alive then I would consider running new wires.
None of the kits is "painless" no matter what the name says.
The 283 wiring isn't that much different than the original wires. The oil pressure and temperature senders are different and if the PO didn't wire up the original senders, that may be why these gauges don't work. The other gauges should be OK.
The previous PO did some creative things with the wiring. I've had the beast since March of '93. This is the 3rd resurrection. 1st is when I got it, 2nd is after it got stolen and vandalized and this the 3rd time after the passenger rear wheel sheared off which sent us into a ditch and onto laid down onto the driver side. I swore I wouldn't rebuild her without doing it right....then I got married and two kids later, now my wife is indulging my other "love interest" with the beast.
Anyway, I redid the main feed from the + post terminal. It did not go through the amp meter. I switched out the ignition and after replacing the main feed from the battery, it starts right up. That's amazing after an 8 year hibernation. I stripped the entire wiring harness of it's electrical tape shroud and started isolating circuits, separating each switch with it's wires and pulling them out of the dash. There are some bare spots along the wires.
I have a HAYNES manual wiring harness example. The PO took full artistic license w/ the wiring. The headlight white w/ black wire has a place that splices out 4 or 5 different places. The alternator has a splice that spreads out once and then up that splice branches off two more times. I copied a few threads about the chevy V8 alternator hookup and will do a little research before starting on it this weekend. I figured on replacing all of the light bulbs and testing wires from the switch to each of the lights.
What would you recommend in dealing with the green residue/white powder on the wiring connectors? Are butt connectors ok or should I use the moisture resistant butt connectors? What gauge of wire for the lights? What gauge for the head lights? Thanks for your advice in advance.
You have to love previous owner wiring. I'm on my second resurrection of my rig. I spent an entire weekend one winter pulling out hot leads from the underdash harness that went nowhere, and removing crimp on connectors and twist and tape, wire nuts, scotch locks, you name it. Some wires were taped up with duct tape and masking tape. I redid everything after a small dash fire. As you can see I had quite a surprise when I pulled the underdash harness. Everything is either waterproof solderless connectors or solder and heat shrink now. I still haven't put in new fusible links right off the battery yet, but that's next.
Since you have the harness open and the circuits isolated, you are about half way done. For corroded contacts, you can either rebuild the OEM connector with new conectors (make a tool to remove them from the connector, or get new waterproof connectors. Otherwise, you can polish shine them up with a wire brush, but the female ends sometimes loose their spring tension. Solder all the connections and use shrink tube. The nice thing is that Toyota used different color codes for the different circuits so it isn't hard to find the right wire. It is a good idea to use different colors for the new wire.
