fj40 to run biodeisel
here
wanna convert 40 to run a deisel so I can eventually run bio fuel.
what motor would be best ? I was thinking of calling Pierre's in Canada but I have no idea where to start . I will be having biodeisel at the house so it is gonna be conveinient to have my trail rig running it also.
PVCruiser said:
Run a 3B or 2H with a Turbo. Cummings is too heavy and awkward. Ask the guys in the international section...
*cough*bull*****cough* :flipoff2:
The 6AT is a proven engine as well, and fits in a Cruiser rather nicely. It's quieter than a 4BT and revs higher at 3600rpm. They're cheap, parts aren't too bad, and they're very driveable.
That said, I'd do a 4BT for torque (MONSTER TORQUE!), mileage, and parts availability. So you might want to clearance the oil pan, no big deal.
Minipigg has some ideas about the VW V10 diesel as well....
I've been thinking about this as a workable Idea as well...don't know if you know but there are a bunch of different websites dealing mainly with BioDiesel. I'll get those on here later, unless somebody else does before me.
greasel.com and biodieselnow.com are both good websites to read up on this. Check Biodieselgear.com, too. They will send you an e-mail with a download that tells you pretty much all about how to make it. enjoy!
I thought about bio diesel for my delivery car.......... I would be required to submit to the state of FL the number of gallons produced or used...... They need this info to assess the hwy and road taxes that are usually rolled into the pump price. If you are not using the car for business, you should be okie..... I WONT TELL.
John, you've likely seen this site but if you follow some of the links it contains it'll lead you to enough info for a few good reads. http://cruisers.shoumatoffmedia.com/
Apparently the 6.2 and 6.5 GM engines are a popular choice in Australia as I've seen links to three outfits in the business there of making the change to them in Toyota and Nissan vehicles. Didn't keep the links though they may have been somewhere in the above site.
I think that the boltup for the GM diesels is very close to the same as that for a small block Chevy so some of the AA stuff might work to do an install of the diesel.
Mudrak huh ? that might be the answer. I am kinda lookin at havin a shop do the job just to expidite things and Pierre's seems to know their shiat well. The cool part is that with low gears the turbo deisels actually get into a rpm that they make some decent power. Veggi oil is the future.
Going to have to agree with you on that one. As weird as it sounds, veggie oil's benifits are greatly out weighing those of traditional gasoline. First off, much cheaper (especially if you can convince your local heart attack shacks to give you their used oil), replenishable source, and it'll make your engine run much, much longer. I'm still surprised that some car company hasn't jumped on it yet. Probably because it hasn't gotten enough press yet...
Will be cheaper, right up to the point where they pass legislation prohibiting the improper disposal of waste vegetable oil, and set up a tax structure for those refining their own fuels….great idea, but only a matter of time, just like anything else....
Hope it works out well for you guys!
Good luck!
-Steve
no s*** steve you got it right on the money!!
car companies are too busy playing with lame ass hydrogen and fuel cells.
BTW, you dont have to do anything to the engine to run bio, just filler up and go.
Rhino, your right about the engine, but I do know that you have to change some fuel lines. The BD will eat through the old lines.
yeah, it does depend on the ratio. I thought you meant your friend just threw some in at 100%. Then he would have for sure had to replace his lines by now...
