FJ40 TIRE/WHEEL HELP
Fort Lauderdale
68 FJ40 with 5" lift. Im currently running 35x12.5x15 with 1" spacers. I want to replace with 35x12.5x18 or 20's. The goal is to get a few inches outside the wheel well without the spacers. Im told with a 10 or 12" wide wheel and a -24 offset I would still need the spacers to clear the control arm. Anyone have this issue or a alternate solution?
Do you have a P/S conversion? If not you’ll also need to consider relay rod clearance with 35s.
I’ve never run larger diameter rims, but 12” would seem wide for 12.50 tires. I’d check the recommend width and run to the narrower side of the range.
The need for spacers will vary depending on the rim design.
Yes I have p/s
I have
