69FJ40 What am I doing wrong? Rebuild kit installed. Trying to get the arm on the splines and I can’t draw it down past about 50%. Old splined shaft fit .
If lined up, put nut on and tighten. It’s tapered so not going to go any further by hand.
Did that and used a 12” breaker bar but it is stopped.If lined up, put nut on and tighten. It’s tapered so not going to go any further by hand.
I paint marked it before I took it off. Also, because of the tapers, it wouldn’t fit in on the wrong side on mine. Definitely the right side.Yeah, make sure not upside down.
What kit did you buy. I could not get the one from Cruiser Corps to work either.
I bought theirs because of cost. Mistake! Not a chance of getting the splines to work. They didn’t answer my email. Bit the bullet and went with SOR. Better fit but quite a bit of work to draw the arm on. After I took it out of the vise and installed it on the truck, I could get better leverage and get it on further. Going to drive it and then torque a little more.What kit did you buy. I could not get the one from Cruiser Corps to work either.
