ksemerdjian
So I'm tossing around the idea of power steering and I realize that most prefer the Saginaw or the ifs steering setup but the mini truck setup seems to be the only option if you don't want to cut into the frame or fender for clearance. I had an 85 4Runner back in the days and remember that all it had was a tie rod and drag link with the push pull steering box which is used for the mini truck power steering conversion but I also understand that doing the mini truck setup doesn't eliminate the relay rod on the 40. So the question is can you use the steering arms from a early 80's 4x4 on the FJ40 front axle to use the mini truck setup and eliminate the relay rod or is that not possible?
