fj40 round tail lights bulb replacement
UPSTATE, NY
'68 fj40- Trying to remove the red lense so that I can discover what color wire feeds the running light. The lens and chrome trim are loose from the housing but don't seem to want to separate. May also need to change the bulb down the road. My real goal is to get running lights on the front bib to function properly. Right now they are coupled with the turn signal fender fixtures which isn't right. Also, is there any wiring diagram out there that has printing big enough to read! The Haynes manual wire colors are too small to be legible. Thanks
Thanks to all! Will try going after the lens again. While I have your attention...Getting a 'hot' feed from the green/black harness with the switch turned off. Considering running a wire from the license plate light in the rear to feed the front parking lamps. Any thoughts?
