- Joined
- Apr 19, 2006
- Threads
- 33
- Messages
- 155
Starting the new year I'll be gathering parts for my mild spring build. The plans are to run coil overs front and rear and link it up. I'm running a chevy 350, a sm465, then adapted to a toy 3 spd case to keep the offset rear axle.
So right now I'm looking for a axle swap that will give me more width for stability, but also allow my center section from my current FJ40 stock (as far as I know) rear axle. It has gears with an ARB, thats why I'm pushing to keep it.
I heard about a FJ80, will it work? Any others? Can anyone answer the questions about the FJ80 or another axle they suggest?
Can the center section drop in?
Will the axle shafts have the same spline count as my stock FJ40's ARB's?
Does it have disc brakes? Easy to convert?
Same wheel bolt pattern as my FJ40?
Any big strength differences? (decrease or increase)
Ebrake mechanism?
A side question: if the ebrake is moved to the axle, is there an easy/cheap way to remove the one on the back of my t-case?
Thanks for the help, keep an eye for the suspension tear down in a few weeks
Ebrake mechanism?
I can't think of any other centered rear axles I like... 60's have a huge pumpkin and different bolt pattern, 44's aren't much of a gain.
