FJ40 manifold question
North Idaho
I will be installing my fj40 exhaust and intake manifold tomorrow. I had the manifolds milled to cure an exhaust leak. I checked on some old posts and found out that I should use some ultra copper high temp gasket maker on my manifold gasket. My question is do I apply it to poth sides of the gasket or just the outer side. Also another post said to just apply the sealer to the exhaust port area not the intake....Is this advisable? Or would it make the gasket surface uneven? Thanks for any help on this.
If you are using the stock manifolds, and not a header, you should not need to add ANY gasket sealant. A quality manifold gasket should be sufficient.
Hth
Mark A.
Thanks for the info Mark. That is what I will do. I appreciate the help.
I use the Permatex Copper COAT Spray on all exaust, intake manifold, and head work I do. Though you shouldn't need it, its a peice of mind thing for me. If anything it makes the gasket tacky on both sides for a good seal. Which to anwser your question I've seen people put it either way, I spray a light film on the head, and manifolds then put the gasket on and proceed to torque it down from there. I've seen other guys put a film on the gasket it self on both sides. In the end it comes out to the same results.
Do not separate the manifolds unless necessary. If the manifolds are straight within the factory spec (2mm/ appx.080"), then they don't need to be machined. If you can't see any light, then you're way better than 2mm. Shine a tiny flashlight behind a metal straight edge to test. I used one FelPro manifold gasket. I used a light spread of "copper" on one side and "black" on the other. It works just great with my Jim C rebuilt carb.
Max
Thanks to everyone for the good info. I got it all put back together this morning. Have not fired up up yet as I have to charge the battery. Everything looks good.....Hope I don't have any leaks. I had the manifolds milled at a local shop. $100.... Fair price I thought. Thanks again for the help.
Gary
73 FJ40
