I want it stretched so that I can seat people at the back facing front and comfortably (same orientation as the driver and the front passenger) instead of the usual jump seat setup. I use my truck as a daily driver and I usually travel with friends/family during weekends. And it's quite unpleasant to be sitting at the back with your head turned to the side, looking at the direction where the vehicle is going, over long distances. So I thought about stretching the middle part of the frame so i can have good legroom and a little space for baggage at the back of the second row seat.Why do you want to lengthen it? You're preparing to undergo a tremendous amount of work here....
THANKS NorthFJ. Now I have ideas of adding length to my frame.Check out this build thread of a local guy to this area that did a stretch, turned out really nice but, as you'll see from the thread, he put a lot of work into it:
https://forum.ih8mud.com/showthread.php?t=182303
Good luck with your project!THANKS NorthFJ. Now I have ideas of adding length to my frame.
Thanks. I will pursue my plan though especially now that i bought a new suv.Yeah good luck. I cut the whole rear of my 40 at one point and re-built the tub using brand new sheet metal and mandrel bent DOM tube. That was fine for my wheeler but it took FOREVER to get things right. Frankly, I think the effort involved with what you're envisioning will not be worth it. I bought an 80 series because it has the seating my 40 does not.
