FJ40 headlights
What's everyone running for upgraded headlights? I prefer lights that have a stock (or close) look.
I'm running Round Eyes headlights and an upgraded harness. Happy with them (vast improvement over stock), but if I was doing it again I would go with City Racer LED's. The Round Eyes do look stock.
I’m running the Koito flat face headlights, came from Toyota with a prebuilt harness with relay to run right off battery positive. I didn’t need it since my electrical was all redone with current gauge wiring, but they aren’t HID. Not super bright like HID but I don’t need that. I’ve also got OE glass bulbs (now my wall art) but I like these since it’s just a simple bulb swap if/when the time comes.
I offer My KUSTOM KOITO LED Head Lights KIT :
- using the base kit as a platform , i have Sourced the Most Premium LED H4 Bulbs on the market today , they feature a solid glass lenses over the LED's sealed with o rings ,
- short compact de-fusers / heat sincs to fit in older 40's with solid headlight buckets
- are 100% water proof in every way
- work in total Harmony with the oem Toyota KOITO semi sealed beam head lights kit mentioned above
- i personally run my kit , and have no , not one negative aspect to report ...
- and , FYI , if your head lamps are properly adjusted post
LED KUSTOM KOITO KIT install , then I do not , and you will NOT blind on coming drivers or traffic .............
do not fall for this urban legend and wise tail .....
i adjusted mine to factory specs , and have never had a issue like this in any way
here is the link , please take the time to see what i have to offer , and explore all the TECH spec Data i have taken the tiome to spell out in east to understand format ................
Thanks matt
Click link here :
