FJ40 Frame questions
NE Texas
I have a 78 FJ40 that I am about to start restoring. A couple years ago I found a really nice body for it. Now I am wondering about the frame. It is severly rusted to the point of flaking but no holes in it. I can hit it with a hammer and it sounds solid. I guess my question is, how thick are these frames? I would like to replace it but have not had any luck finding a frame. If I find one what years will work? Thanks for any help you can give me - Rusty
Welcome.
Frames are close to 3/16" steel, hot rivited and welded construction.
1974-1978 will swap.
1972-1973 will also, but tube crossmember will be tight for the four speed tranny, but it will work, and tail lamp assemblies for the later truck will not work without frame mods.
1971 and earlier use a different steering gear box mount, which, does not matter if you are going power steering. ;)
Good luck!
-Steve
pictues would help.
Mine came from IL and it has a lot of rust on it but I think it is pretty solid. I did have to patch a hole in the rear of the frame but it was not like in the middle of the frame that I saw on a 40 that was for sale. The hole was right under the front driver door. No way I wanted to mess with that repair. Mine was no problem to fix.
