FJ40 & FJ55 Steering Question
Howdy,
I don't have either an FJ40 or FJ55, but I have a question about the steering setup of these. Am I correct about:
FJ40 has crossover draglink steering, both power and manual steering?
FJ55 has push-pull draglink steering, both power and manual steering?
Thanks for taking the time to answer my trivial question. I have searched the web, but am not positive about my conclusion.
Andy
'87 FJ60
A 40 and 55 have the same steering set up....whatever you want to call it....
The parts from the bellcrank to the axle are the same between both...the link between the gear and the bellcrank is different, the 40 series is adjustable, and the 55 is not IIRC.
Good luck!
-Steve
Thanks for the reply Poser.
So both have crossover steering?
By crossover, I mean the pitman arm connects to the drag link (maybe called center link?), which connects to the steering arm on the opposite side knuckle (crossing over from the driver side to the passenger side), and the tie rod brings control back to the driver side knuckle.
Push-pull is what the mini solid axle trucks have. The pitman arm connects to the drag link, which connects to the steering arm on the same side (driver side). The tie rod gives control to the passenger side knuckle.
I thought I once saw an FJ55 picture that looked like Push-Pull steering. My eyes or my memory must be going. I forget what the third thing is that goes! LOL.
Andy
The steering box moves the pitman arm which moves the drag link which moves the center arm which moves the relay rod which moves the tie rod which turns the wheels. ;p
I was thinking the arm is different on the frame pivot between 40/45 and 55's. Also thinking the length was different on link arm.
ditch the center arm...that's all I have to offer.
just checked, the 55 rod from box to center arm is aprox 10" shorter than the 40 version.
you could cut down a 40 rod and have the tube threaded, I thought Mark A was making these a few years ago, as the 55 rods have fixed ends.
