Fj40 Drive Shaft Interchangeability
I've done a search, but I haven't found anything difinitive. I've read where people have use fj60 shafts or mini truck shafts, but they didn't say if there were modifications necessary. I know that the older 3 speed t-cases have a different pattern, but I'm not sure about the 4 speeds.
60 series front shafts with the CV will bolt up to your companion flanges on the t-case and the diff....provided you are using the larger ujoint/bolt pattern flanges on your diff and t-case currently.
Mini-truck will not, unless you drill out the flange...
Good luck!
-Steve
Just size of fastener used, the pattern is the same on the early and later three speed flanges...
Four speed flanges were the same until 09-85, when the 60 series went away from the CV front shaft, and the bolt pattern changed again to a larger pattern.
Klear as mudd?
I'm still just a little confused. Are you saying that the holes in the output flanges on the t-cases are identically spaced just the size of the studs/bolts changed, or are you saying that the size of the pattern increases do the bolt holes are farther apart? Sorry this is taking so long for me to understand. I don't have the money to buy a custom shaft and there are a few mini truck shafts on ebay I thought I might pick one of them up and get by for a while.
You WILL NOT be able to bolt up a mini truck drive shaft to a Land Cruiser companion flange WITHOUT CHANGING THE BOLT PATTERN ON THE FLANGE, by drilling different holes, PROVIDED you have the ROUND style flanges, that would permit you to drill another set of holes in it, and NOT the square ones, which were far more common, and WOULD NOT allow you to change the bolt pattern, in which case, you would need to perchase new flanges...
I would look for 60 series CV style front drive shafts....they are out there...
If you do not have money, they you must have paitence....
JHart said:
Are you saying that the holes in the output flanges on the t-cases are identically spaced just the size of the studs/bolts changed, or are you saying that the size of the pattern increases do the bolt holes are farther apart? .
" Are you saying that the holes in the output flanges on the t-cases are identically spaced just the size of the studs/bolts changed "
Releative to THREE-SPEED companion flanges...this is what your question asked...the one that I put in quotes....
" or are you saying that the size of the pattern increases do the bolt holes are farther apart? "
On FOUR SPEED flanges, the bolt pattern changed in mid-year 1985...
In Jan-1974, the bolt pattern changed from the smaller THREE SPEED style, the the FOUR SPEED style...
The bolt circle diameter is not the same between the three speed, four speed, later four speed, and mini truck..
good luck!
-Steve
resurrecting an old thread. can anyone tell me if the drive shaft flange of a 1972 fj40 will mate to the driveshaft of a 1977 fj40 through the u joint?
ie. will this part (1977)…
mate to this part (1972)
maybe it’s easier to ask if they use the same u joint? that i haven’t searched for but i will
i replaced a 350 but with a 4 speed in my 72. i have both sets of drive shafts for the 72 and the 77. drive shafts need to have lengths adjusted but two of the four slip joints have bad wear. we’re just trying to find the simplest combination of using the parts that are worth saving. the front 72 shaft is still one of the good ones so i was hoping i could just swap the flange through the u joint on slip yolk (transfer case side)
