Fj40 Disc Brake Conversion
  • Thread starter Thread starter 69fj40
  • Start date Start date
I was also thinking of how that thin plate can fail (crack) on its own with all the factors involved- flex due to the vibrations caused by the pads hitting the rotor + repeated heating and cooling of the thin metal transfered from the caliper to the thin plate + the fact that you welded it and that could have weakened the plate + the caliper wanting to rip off the plate from the force of the rotor spinning.
I am deffinitely not a physicist, but somehow it seems to me less (or atleast different) force is put on the plate from the drum brake pistons pushing out on the brake pads, than hanging off the end of the plate.
These brackets are less than $100 new, and you can easily make your own too. Just doesnt seem worth it to half ass brakes.
-Dustin
The drum brakes transfers rotational force into the backing via the wheel cylinders. These are mounted with 4 8mm x 1.25 bolts for each cylinder AND there is a molded in round projection on the back of the cylinder that is a tight fit into a large hole on the backing plate. The cylinders are mounted 180 degress apart which distributes the load equally over the whole plate. It looks to me that the disk brake bracket you built would also spread the force out equally over the plate. However I gotta agree with the others when it comes to brakes: Unless this is an off-road only vehicle then you are putting others at risk should your brakes fail on the road. Gotta admire your ingenuity though!
Brake Force
Lots and lots and lots of pressure on the front brakes. I think you get about 75% or even more of you stopping power from your front brakes.
As far as hurting others with your brake design. I'd rather take my chances with someone like you, than any old lady driving a brand new Cadillac.
I got rear-ended by and old lady while I was sitting at a red light. I was in the company one ton truck. I didn't even get out to see if there was any damage.
J.R.
Peesalot
The rotors are for early 90's GM heavy half ton 4wd reg cab, calipers for 80's Monte carlo. Same parts as for the rear disc conversion.
Dustin
Tell me where you found the front brackets for under $100. The rear brackets are not the same. I searched all over and only found complete kits that must have been gold plated!
