FJ40 Corner Glass
Lancaster, CA
Can someone tell me the differences between early 40 corner glass (not corrugated) which I believe goes up to year 71 and after that. I have a hard top that I'm restoring, but it is a mix of different parts and I can't tell what I have. It is a hard top with a lift up hatch.
Mid 1965 to 7/71 used glass and weatherstripping that both are recessed. 7/71+ the weatherstripping came out past the metal glass was flush with metal. To do that the earlier glass has smaller dimensions.
So, you can't use later year weatherstripping with the earlier glass? I do have the pre 7/71 glass that had the key for the weatherstripping.
Hey Mightymes, I believe I know where a pair of corner windows could be had for really cheap if you need a set. I'd have to double check the vintage though.
I'm wondering if I could use later model (after 71) in my side panels?
This is from cruiserparts and seems to support that idea.
I changed my top from the early two piece weather strip to the later one piece style, the glass size is different.
some good info on it here
So, just to make sure I'm right one this. I can put later model glass with the corresponding weatherstripping or use what I have and get the weatherstripping with the keys in it? If so, does anyone want to trade older glass for some newer glass!
