Hi I have a 74 FJ40. I am having problems with my rear brakes. The previous owner did a front disc conversion already on it and when I check the rear brakes 3 out of 4 wheel cylinders were seized. I then replaced the wheel cylinders and the lines snapped so I remade all new line in the rear. Brakes just go right to the floor. Previous owner provided a brand new master so I bench bled that and replaced it as well and pedal still goes to the floor. 2-4 puts it will get a hard pedal. Adjusted my brakes so that they were right tight and that did not make a difference in the pedal. When I vise grip the rear flex line it will have a hard pedal right away. Also Previously how the wheel cylinders were positioned were opposite of the info I see and the part numbers I got. How the cylinders were for the drums were Driver side; Left piston goes up and right cylinder goes down. Passenger side; Left piston goes down and right piston goes up. Would that have a play on my pedal?
