If you found an 81 with rust, you'll need front and probably rear floors. This can be a bitch kitty. Normally, the front body mounts are compromised as well, and must be refabricated. also, the rear body mounts will be s***. From this standpoint, if you truly want to make the truck roadworthy and safe, you're better off with an earlier model with good floors. 79 and later came out w/ a double floor in the front to ward off the heat from the cat converter. I've done a bunch of these late model trucks, it literally adds months to a proper re-do. (at least at my pace!) Brace every body opening well, with accurate measurements for door opening, body height, etc., and don't even start on floors without a pretty comprehensive knowledge of welding and fab.
