What I have – 1987 Suzuki Samurai, 1.6L 16v, Stock Samurai Trans, 6.5 Transfer case. Curb weight is a touch over 2000 lbs. Loaded up ready for the trails, myself included, it weighs out to 2440 lbs.
The next step/upgrade – 1978/9 FJ40 Land Cruiser axles and 38” tires.
After crunching numbers using http://www.lepayne.com/gears.html I will need to lower my R&P, but by how much? Stock FJ40 axles have a 4.1 ratio. Ratios I’m considering are 4.88 and 5.29. I’ve included where the rig is now, and the effects of larger tires/lower (4.1, 4.88, 5.29) R&P.
As it sits now - 3.73 R&P, 30” tires, 4% gear reduction on high side, 149% reduction on the low side. Low craw ratio is 88.47:1
4.1 R&P, 38” tires, 10% gear increase on high side, 116% reduction on the low side. Low craw ratio is 97.33:1
4.88 R&P, 38” tires, 8% gear reduction on high side, 157% reduction on the low side. Low craw ratio is 115.84:1
5.29 R&P, 38” tires, 17% gear reduction on high side, 179% reduction on the low side. Low craw ratio is 125.57:1
I have additional comparisons in the areas of gearing and MPH range for each gear of the transmission to Stock Samurai in a .jpg format. I’m having issues posting them for some reason. I can provide if needed.
Once I figure out (with your assistance) the R&P that will fit my need, I’ll be pimping ya’ll for suggestions on R&P manufacturer and source for purchase.
Thanks
Rob
Thanks
Rob
