FJ Power Loss
northern utah
Hey all,
Caveat: I am not a mechanic, but I am kinda old so I've seen many car issues over time :)
I have a 76 FJ, runs/starts well. Lately when i get to the upper end of a gear I lose power, acts like its almost not getting gas.
I let it sit for awhile (30 mins or so) then power seems to be restored.
I thought maybe the fuel filter, changed it out yesterday and ran it for an hour and it had great power... and i sawed open the old filter and saw no sign of blockage or debris..
Today its back to the same issue. AND tonight I get a little blue smoke out of the exhaust.
Any ideas? I bow to your collective knowledge ....
Thanks
If it was not getting enough gas, it would most likely start jerking, so I wouldn’t start there. ‘76 has points, and if the dizzy is worn ( what the heck, it’s only 44 years old!) you might have spark/timing issues at higher revs.
1. Check air filter
2. Check vacuum
3. Check base timing
4. Check dwell.
5. Report back
Best
Mark A.
www.marksoffroad.net
If your soft fuel lines are old, they could have pinholes. When the secondary kicks in, under load, the fuel pump will suck a lot of air. Could be a loose/bad clamp too.
if soft lines are old, I would replace them.
When engine dies, under load (uphill, pedal to the floor), turn the key off and safely coast to the side. Remove air cleaner, check carb sight glass - is there fuel in the sight glass?
Will the engine start right back up, or do you HAVE to wait 30 minutes?
If the blue smoke occurs when accelerating:
- check/replace your PCV valve. If it doesn’t rattle when you shake it, tap it a few times to break it loose. Ultimately, replace it.
- could be worn valve seals
- could be worn rings
Don’t run right out and rebuild/replace the engine... figure it out first.;)
Pics of the plugs, please. I'd bet that it is actually oil, because you can see it out of the exhaust, and a plug will oil up if you are at the point of blue smoke. My 2F needed new valve stem seals, now the plugs are clean.
