- Joined
- Dec 24, 2011
- Threads
- 2
- Messages
- 13
Terrain Tamer suspension install
I got my suspension recently from @wardharris at Cruiser Brothers, the install on it went for the most part, smooth as butter, the only things not smooth about it was the de installation. Pro tip, spray some penetrating oil on every single bolt you can reach in the weeks leading up to the install, you will thank me later for that tip.
Below you will see some pictures of the process that me and my helper went through to undo and redo every bolt necessary and most importantly, how we got the spring out and back in again
To get the front shocks out, use a shock adjusting socket wrench, they exist, we did not use it, and instead used a myriad of wrench’s and socket drivers to accomplish the task. The issue was not necessarily the tightness, but instead that the location of the top nuts were shall we say awkwardly positioned.
Passenger Side
Passenger side tools required
Driver-side tools required
For jacking the axle down from the car we tried several methods, but the most effective was the bottle jack that come stock with every fj80. It worked beautifully. After removing the spring continue jacking a few more pumps to make room for the new spring, since it’s a bit longer. Watch the body to axle brake line…I was told it would suck to rip that off.
Method to move the axle
Old vs New spring
Be very careful while jacking it down, to not jack to much, as there are brake lines that you should not break, horrible pun, sorry just had to…
The brass looking tube on the axle there is a breather. The PO (my helper) installed remote breather filters and the hose popped of…no biggie. The black oily goopy mess stuff is the brake hard lines.
Now it’s time to setup the shock, this is what it should look like top and bottom, place the 2 other pieces it comes with at the top and bottom of the mounting points on the car
Front passenger side done
The most challenging portion of this job was the removal of the rear shocks, there was no way without the special tool we couldn’t find, to lock the shock in place and rotate the nut, we got around this by using the tried and true vice grip. After we finished the job, I read the FSM, and it said you could remove the top shock mount with 2 bolts, this would have ben good to know before I started, but meh, job still done!
You do have to push the bushings into the rear shocks, this is extremely easy if you have a vice…
You simply lube it up with some anti seize, then you line the bushing up with the hole, and you press, easy peasy but heres a picture
Here is what mine looked like before and after*
One side done, il let you guess which… please don’t shoot the messenger but I forgot to take a full before picture, but it was level at the height of the rear before I did anything to it
All done
Coming soon to a forum post near you is a post about how to do the install of the steering arms and steering stabilizer.
Passenger Side
Old vs New spring
All done
