fj 80 starter problem
I came home one night and turned off my cruiser. When I went out to start it again all it did was click. The battery had plenty of power. It clicked several times and then started again and now it just clicks. I replaced the starter. It still clicks after the replacement. What other components can keep the starter from turning and still produce a click?
Did you replace your starter with OEM or aftermarket?
Quite possibly the starter relay, or
bad ground to the engine from battery, bad connection on the battery terminal ground or positive terminal,
Yep check all of these things
I have the same problem, I replaced it with a Bosch (aftermarket) which I had on other vehicles before. This one about a week later started to do the same, except mine doesn't do anything, no click. I have to hit the starter with a piece of wood in order to get it going. Someone suggested me to put a Ford starter relay in the positive battery wire, somewhat the same setup they do for VWs, but I think this just might hide the real problem. This weekend I'm taking the starter back and get another one.:cheers:
My starter was doing the same thing. A couple taps with a metal pipe and she'd fire most times. I replaced it with the larger 2 Kw starter from Toyota and have not had a problem since. In fact, it may be the placebo effect, but I think the engine starts faster now with the bigger starter. You can tell it is different and for the better that's for sure. I called CDan and another cruiser friendly dealership on here from SC (can't think of the name off the top of my head) to get a price quote and then went to my local dealership to see if they would match the price. They did and so the part got to me quicker and I am establishing a relationship with my local dealership which will hopefully pay out in the long run.
Yes it was an aftermarket Starter. i checked all the wiring and it looks solid. Thought i would by pass all of the other componants and test with a remote starter switch. will it produce the same problem? has anyone done that? I heard it could be a bad EFI relay or worn Egnition switch?
I tested it with a VOM for correct Voltage and Jumping it with another car made no difference to the problem. I did not have it load tested. Do you think that could be it?
How about some basic information regarding your truck. Country of origin, year, mileage might help.
Just to update this issue. This is my second vehicle and need it to run to beat the cold here in South Carolina. I attached a remote starter switch to the lead between on the solenoid and the battery cable on the starter. This operated the starter properly. By turning on the ignition and using the remote starter switch it started just find. But still only clicked when wired properly. I then installed a 20amp momentary switch on the dashboard wired to the battery and the and the solenoid post on the starter. It has run properly all day. My conclusion is that the Ignition switch or another component between the ignition switch and the solenoid is not allowing the correct amount of current to activate the solenoid plunger and engage the starter motor. If any of you know of which component tends to fail most in that circuit it would save me a lot of trouble shooting time. Thanks
Sounds like a possible ignition switch failure, or the neutral safety switch.
Either way your work around solved your issue.
I used the down button for the antenna to start our Cruiser, it fires the Cole Hersee relay wired to the starter.
Welcome to IH8MUD:flipoff2:
