FJ-62 ATF level question.
Happy Valley, OR
Okay, I've got a quick question for the experts out there regarding my transmission fluid level. As per my 1988 Owner's Manual, I am supposed to check my transmission fluid level while hot (160-175 degrees). I followed the procedures outlined in my manual last night, and am currently about 1/8" below the low level mark (hot). However, when I checked my fluid level again this morning while the engine was cold, the level was approximately 1/2" above the full mark on the "hot" section of the dipstick.
According to page 179, section 2.c., "If the transmission is cold, the level on the dipstick should be in the "COOL" range on the dipstick. Similarly, if it is hot, the fluid level should be in the "HOT" range".
My question is this: Is the fact that my transmission fluid is approximately 2 1/2" inches above where it should, when cool, an item of concern? Does anybody else have the same issue, or do I have something that needs looking in to? Thanks in advance for any, and all, advice. Regards, Joel. :)
Do you run an aux. tranny cooler?(if your not you should be), if you do there is fluid out of the system and that could account for the level difference. Also remember the engine should be running with the trans in park. If you check it on stat up at least run it through the gears P-n-r-d-1-2-3 back to Park then check the level as there are tons of passageways that fill up with fluid.
Dynosoar:zilla:
Did you wipe and reinsert the dipstick for the cold check? Had you run the selector through the gears (as Dynosaur recommended). I'm suspiceous that you have a higher level IN THE PAN after the truck has sat for a while, and air up in the transmission that gets displaced by ATF after running.
Yes, I checked my fluid level while the vehicle was running, and in park, on a flat surface. I also ran the shifter through the different gears, as specifed in the owner's manual. Finally, I did both sets of checks (hot & cold) several different times, in order to ensure that I was getting an accurate reading. To answer Dynosoar's question, no, I don't have an auxiliary tranny cooler on my rig yet, although that is on my radar of things to do. I have a low-mileage vehicle, with only 110,000 miles on the odometer, and recently completed the "Rodney flush", replaced my oil pick-up screen, and transmission pan gasket. Does your fluid level read in the correct range when cold?
I had to resurrect this thread. My FJ62 is the first auto tranny I've ever owned so I'm having a hell of a time trying to get a good read on the fluid level. i got a slip the other morning so decided to check the fluid. I checked it while the rig was off but at full temp, fluid was barely at the bottom of the cold range. Let it sit for a couple of hours and checked again, totally cold, and the level was at the top hot mark. I checked it again the next day using the FSM method, full op temp, ran through P, R, D, 3, 2, L and back, left it idling, and there was NOTHING on the dipstick. Wiped and ckecked again and still nothing. I know I have a slow leak out of the tranny pan, but when I replace the fluid and filter this weekend I want to be sure I'm putting the right amount back in! Anybody have advice here?
With it idling cold (after running through the selector) add fluid through the dipstick tube till it comes up to near the top of the cold range (might be difficult to read, as you'll have a fluid coating inside the tube that transfers to the dipstick). Once it's there, give it a check in different situations (cold again, hot after some city driving) to make sure its in the proper range. IIRC, mine doesn't hit the hot range unless the tranny has really been worked hard. I think the cold (but running) level is going to be the most accurate measure.
Check it when its hot, after you drive around a while. Maybe 15-20 minutes or more.
Would it be possible for the gear oil in the transfer case to leak into the transmission while the truck is sitting and giving you a false reading of high on the trans dip stick? That could explain what you are seeing.
That would be scary. Fortunately the fluid is red and clean looking. I know the tcase is leaking a bit too and that oil is pretty grimy (changing that asap too). I would think that mix of atf and gear oil wouldn't still be that red.
If the fluid is still clean and bright red, you are probably safe. That would pretty much be the worst case scenario and an unlikely one as well.
Try driving it a bit more and checking the fluid when hot and cold one more time.
