Hi there – I have a 1977 US FJ that came with the 84112-60010 Switch Assembly. The current Factory 5pin harness side connector plug is intact and in good solid shape. The small RED and WHITE color coded wires feeding the little golg spring loaded twist bulb socket base that enters the rear of the 84112-60010 is as it came from the factory too. The twist bulb is burnt out so I have reordered a new one to see if it works. The issue that I have with my current switch is that the Cluster lights don’t work at all. I put a “generic” light switch in from Painless and was able to get the Cluster lights to work so I know they are good. I essentially mapped 4 tabs on from the Painless switch to TB - Fuse (tail) 15A, HB To Fuse (head), TL tail light, and PL to Pilot light (i believe this is the one that powers the cluster lights) - See attached picture for the connector mapping. I also checked all the bulbs in the cluster. I purchased a 84112-60020 4 prong light switch and was wondering if I someone could help me map the 4 prongs to the correct wires on the 5 prong harness to get everything to work, minus the Reostat. I tried plugging in the 4 prong to the existing harness and it doesn't fit. Silly me for assuming. I would guess if mapped correctly, this would simply mean that the cluster lights can’t dim or brighten because the new switch isn’t dimmable. The cluster lights would just come on or go off when pulling the light switch in and out. I am happy to take pictures or whatever is needed for help. Thanks in advance!
