FJ 40 Engine Block Serial Number
Colorado
Hi,
So I have a fj40 block with a serial number of "F" thats all it says.
Any thoughts on what year it is
Thanks
CRG
Usually a non serial large item like a frame / engine block will be from a replacement part, warranty or not. So, if someone needed a new block, probably had no serial number.
Casting date is on the manifold side of the block. Usually toward the front on F blocks, but might be toward the rear on a later F service block.
Cylinder head casting date is on top of head, just outside valve cover.
Maybe so, but, if a casting number is there, but no serial number , What's up ?? That is the issue.
