Fixed dash lights - uh, kinda....
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
Got in my '76 Fj40 after work today, fired up and pulled the lights on. No dash lights. Come to find out after I got home and looked at the wiring diagram that this means I also had no marker lights or tail lights. (not good, I drive home in the dark) Figured it was probably the fuse - went out to change it - wasn't blown. Hmm. Came in and read some Mud. went back out to check a few other things. pulled the gauge cluster to see if I could measure anything back there. Couldn't find my test light so I made one with an old trailer light. Measured power at the fuse, both sides, but when I pulled the lights out to the first detent, my test light went out. (that should have clued me in right there) Couldn't get power at the gauges. Didn't really want to pull the switch. Put the gauge cluster back in. Came in read some more Mud. went back out pulled the fuse and found that it was actually broken (end cap) as had been the case with some other Mud folks. COOL! put a new fuse in, nothing. BAAAWW. WTF!!!! Poped the fuse block out and pulled the connectors off the back - They are like NEW!! wow. After reading about what some others have found there I am surprised. No corrosion whatsoever. Put the plugs back on. Looked at the spot where the fuse goes, looked very slightly tarnished. Got large wire brush and scrubbed it a bit. Put fuse back in PRESTO!! WOO HOO!! Wow. a little corrosion goes a long way. At this point got a bit pissed at myself as I should have realized as soon as my test light went out when I turned the lights on that there was a bad connection and that was why I was not getting power.
Put my gauge cluster back in and found that only two of my lights in it are working. Cluster seems to be as bright (= dim) as it was before. Checked the other two bulbs and they seem fine (top two are out) wiggled them around a bit to see if I could get a better connection - made no difference. Are these powered seperately or am I just not trying hard enough?
Any tricks here?
(glad to have some lights back!)
Oh, all this only took me 2 hours out in the freezing rain.
Tips would be appreciated.
Thanks.
Oh, come on... someone must know something about this stuff!!!!
When you find out please let me know?I 'm havin simular troubles!
To answer your question Bruce, yes, and no. Yes, they are powered separately (turn signal indicators) and no, it's not that you aren't trying hard enough. There should be a total of five lamps in the cluster, but only two are for gauge illumination. They don't do a very good job. SOR has a brighter bulb, I'm considering it. Should be available anywhere though.
I wasn't sure what bulbs you are referring to. The turn signal and high beam indicators each have separate power leads. If it is just the brightness of the panel lights that is a problem, you can also widen the opening in the metal shield that covers them or remove it. Sometimes the brightness rheostat in the light switch needs cleaning too. Try one of the spray contact cleaners if this is the problem.
Doh! I feel dumb now. Makes sense now why one of them was blue when I pulled it out!! Thinking about converting to white LED's in there similar to what I read here about someone converting a headlight indicator.... will let all know if it works (and if and when I do it!)
Thanks...
