Fitting hard top early 40
Morro Bay CA
Hello everyone,
Thought I would drop in the 25 section because I thought you guys would have a better idea of what i'm talking about. So I have a corrugated hard top and it fits on fine but it has the long pillar neck so I need this piece to get rid of the gap for the tubing to slide into the tub. Like so....
Does anyone know where I could get a piece? Make it bla bla bla???
Or should I just go non old school and find a 64 newer top?
My pillar pieces were cut off by the PO :rolleyes:
Thanks,
-Joe
Joe,
We understand, been there. Basically two choices: either put a pillar back on, or fill in the gap on the hardtop.
If you're not a purist I would finish off what the PO did by welding a cap with a hole in the top like the later models. That way a later soft top would fit. It should be relatively straightforward to weld up something to fill in the gap on the hardtop, you've got the contour already. If you're not that crafty, you should be able to get a piece of door channel off a junk tub to make a filler piece.
If you want to replace the pillar, post up in the classifieds, you should be able to find someone with a junk tub (or some of the used parts adveritsers).
I have two options for you. Contact LandCruiserSteve. I send him those pillar pieces and few years back, I don't think he used them. I don't think he is on mud much buck I think somebody here has his Email. Or next time you are in the Phoenix area stop by and I will give you the hard top sides from a 64. The 64 had the same top just not the high pillars.
John
