First winter with an 80
Boise, ID
We had a cold snap last week (8* or so) and even now with the temps in the high 20s and low 30s it seems like the cruise is cold blooded. My heater valve is not the problem. If the t-stat wasn't to expensive I'd just throw another in, but I'm not sure it's stuck open as it seems to warm a little to fast for that. Is this just a 91-92 thing with that big ole cast iron block?
Temp. gauge get's up to the middle range within 5 min. or so, or not?
Closer to 15 minutes then 5. Probably about an average of 10-12 minutes to get it anywhere near the middle.
It should warm up a lot faster than that. Might be the T-stat. There was another thread on here in the past month with the same issue...was the T-stat in that case, I believe.
Don't worry,
We have had -30 temps and yes it takes time to warm up. You should be warmed up after two miles of travel. Idling takes a lot longer than running under load.
Think about heating up a big pot of water, it takes time.
you could throw the Tstat in hot water and see if it opens and closes properly, although by the time the cooling system is opened up you're probably better off putting a new stat in as they are inexpensive.
Don't worry,
He said he's been having +20 to +30 temps, though. I could see it taking longer in -30 temps but his temps aren't much different than what I'm seeing right now and mine warms up much quicker (replaced the t-stat last summer).
rat fink,
Chances are it not the t-stat, but the rubber gasket that sits on top of the t-stat. This is what happened to me.
I have a similar situation with my 91. The temp gauge barely registers even after 15 min. of driving. This is in about 35 degree temps. So I replaced the t-stat last weekend. When I pulled the t-stat I noticed that there was only two small pieces of the rubber gasket left. Since I did not order the rubber gasket when I ordered the t-stat (doh!), I just went ahead and replaced it anyway. I'm still having the same issue. I have the rubber gasket now and plan to install it this evening. If this solves the problem I will let you know.
After rereading some of the recent posts on this subject, it seems that the rubber gasket is the key to fixing this issue.
When I ordered the t-stat I told the parts guy "I need the t-stat and gasket". All he ordered was the t-stat and the paper gasket that goes in between the t-stat housing. Be sure to get the rubber gasket, part # 90430-43002.
On a side note, these t-stats are the biggest I have ever seen. It looks like there is even an adjustment screw on top that runs down through the middle. Could this be an adjustment to change the temp. setting?
Mine take a minimum of about 15 minutes or 10-15 miles of driving to warm up. I might order the gaskets and take a peek. The only reason I haven't taken the t-stat out at this point is nobody has the t-stat or gasket in town, so I have to order both. I'd probalby just replace both if I bother ordering. Is there a source for less then $30.
ratfink,
As a follow up. I had some time this afternoon to install the rubber gasket. It made a huge difference. It took less than five minutes to warm up at idle. Of course temps here are in the mid 50's today, so not a real cold weather test. It does confirm to me what others have said about the rubber gasket being the issue here, as long as the t-stat is good.
Oddly enough - my 95 is the fastest car Ive owned in terms of giving heat in the winter. I'm on my 17th car - so thats saying something...
So can you get this rubber gasket anywhere but the dealer?
X1000 on the rubber ring. I just replaced my thermostat, gasket, and ring about 3 weeks ago, and even in 0 degree weather or less, my Cruiser warms up to temp within a few miles. Stays right in the middle of the range. I paid $43.00 at my dealership, but heard that Cruiser Dan is a little cheaper. Ships from the dealer within a day.
For everyone's FYI I pulled apart my t-stat housing today. As was suggested, no little rubber o-ring on the t-stat or in the housing. I replaced the t-stat. o-ring and of course the paper gasket. I haven't fired it up yet, but it seems pretty obvious that the o-ring was the issue.
