First Timer Saying Hello
Orlando, Florida
After 24 hours of ownership I have built up a to-do list. Some is just basic maintenance but other stuff will require verification & troubleshooting. Any help will be greatly received.
1) High idle when cold / erratic idle when warm.
When she is cold the idle is around 1200 rpm. Can anyone confirm if this is normal? Also when she is warm idle can drop from 850 to 550 rpm and back to 800rpm for no apparent reason.
2) I only got one key with the truck but i got 2 remotes. Can the key be cut by a locksmith or does it require a visit to the dealership?
Both remote controls light up when pressed but neither activates the central locking. Does this sound familiar?
3) Front courtesy light doesn't come o. With either front door. The rear light comes on so the switches are on. Front light works when switched manually so not the bulb. Any ideas?
4) looks like I have an oil leak from the back of the engine. Is this a common problem - maybe a crankshaft oil seal or similar?
5) Passenger side mirror is shakey. Is there a quick fix or am I looking at buying a replacement?
6) plugs - Is there a preferred brand that works best in these engines?
Guys thanks for putting up with my questions. I have spent hours today searching for various things without much concrete outcomes. Again any help will be appreciated.
J
